Clutch goes to the floor and stays there.
Got in my car today to move it up to the driveway to do some sanding and when I pushed the clutch in the shift in to reverse it wouldn't go in gear and the clutch didn't come up. Clutch fluid is fine. What do you think it is? Master cylinder? HELP!!!!
Have you noticed any leaks under the car or on the firewall? If not, check the reservoir. Is the fluid dark or discolored? If so then start by flushing and refilling the system. This is likely a hydraulic issue that could, ideally, be solved by a good bleed. Check it out and let us know what you find. Thanks!
