01 Slave cylinder identification
I got a good deal on a ls1 tranny awhile back and I was told a few things about the tranny. A few things I was told about the unit I found to be false and I just want to verify that the slave that came with the tranny is indeed a 01 slave. If you guys have any info in this I would appreciate it. Thanks.
saw another guy post that the slave part number was 15046288
said that was 02, not sure if there is a difference between 01 and 02 part numbers or if that's just more like a casting number for the year spread.
i'm going to be examining the exact same issue when i pull my trans tomorrow nite, as i got my D&D from someone else as well who said the hydraulics were upgraded but i'm having a problem that might be because the slave is the old style..hopefully there is a part number stamped on the slave??
