What is cags??????
Old May 17, 2011 | 08:30 PM
pewterfbody's Avatar
Default What is cags??????
I did the m6 swap on my car and I am about to order this harness on ebay. But it says if I want cags to let them know. Do I need it? The computer is off being reflashed now.
http://cgi.ebay.com/ebaymotors/T56-6...item56422ab88b
Old May 17, 2011 | 09:01 PM
nate0031's Avatar
It stands for Computer Assisted Gear Selection. It forces you to shift from 1st to 4th under slow acceleration. Mine has been disabled, and I've heard of many other having theirs disabled. I doubt I'd ever want CAGS, but Ive never used it (mine was disabled when I bought the car), so I don't know if it's as annoying as I imagine.
Old May 17, 2011 | 10:56 PM
ls1okie's Avatar
I did not hook mine up with my swap.
Old May 18, 2011 | 05:27 AM
Ok so I dont need it then
Old May 18, 2011 | 06:18 AM
ramairetransam's Avatar
nope not needed , its a pain in the *** and lugs the car if it functions.
Old May 20, 2011 | 10:45 PM
Well my question now is how do I wire it where it wont turn the check engine light on where I can get it inspected?
Old May 20, 2011 | 11:51 PM
Vexzer's Avatar
If you are getting flashed have the tuner turn it off. Along with the VATS, 2nd O2's, Canister relays and a few other things. The tuner will have suggestions -talk to him. In the meantime you can bridge that stuff out easily with the right resistors. Many posts in these forums as to how to do.
Old May 21, 2011 | 06:34 AM
F-BodyMind's Avatar
You will hate that damn cags! I know I did in my old camaro. It basically blocks second gear under normal driving conditions, its the worst.
Old May 21, 2011 | 07:53 AM
Well thats the thing He has already flashed it and its in the mail now. But I can just put a resistor in it.
Old May 21, 2011 | 08:23 AM
got-a-ls1's Avatar
cags stands for
Computer Aided GaynesS.
Old May 22, 2011 | 04:07 PM
Vexzer's Avatar
Originally Posted by got-a-ls1
cags stands for
The Gayness connector is on the passenger side of the trans. It connects to the big blocking solenoid. I might have it mixed up with the reverse lockout but you'll get the idea when you look there. Just leave it unplugged and resistor it out & you'll be fine.
Old May 22, 2011 | 06:07 PM
Ok thanks man
