M6 reverse problem
Old May 28, 2011 | 08:35 PM
JrodCamaro's Avatar
Default M6 reverse problem
Going into reverse is a little touchy, I have to hold in in position, sometimes it jumps out even doing that.
I was suggested it was the wear plate on the fork, any other ideas or is this a pretty solid idea?
Old May 29, 2011 | 05:40 PM
Jonathan@Tick's Avatar
LS1TECH Sponsor
Yes, its likely the fork pads. They can wear out/break off causing this issue. When this happens the fork can recieve some wear and be damaged as well. Depending on how much it has been popping out of gear or grinding the gear itself may be ruined. The syncro can be flipped over and used on the other side which will still be new as long as the trans has never been rebuilt and had this done already.
Old May 29, 2011 | 09:50 PM
JrodCamaro's Avatar
Guy before me said hes never touched the transmission, the only time it pops out is when I'm not thinking about it and don't hold it in place (guess i should have left that part out) just something else to learn while replacing the shifter.
How easy is it to get to the fork on the T56?
Old May 31, 2011 | 07:36 AM
Jeremy@RPMTransmissions's Avatar
The reverse fork is pretty easy to get to. You will want to stand the transmission up pointing input shaft down. Most people who build these regularly have a transmission vice to build off of but you can use a 5 gallon bucket with a hole in the lid in a pinch. You will need to remove your shifter base, under the shifter there will be a shifter block with a small rollpin holding it to the shifter shaft. Drive it out and remove the shifter block. Then remove all the tail housing bolts holding the tail housing to the main case. Once you have the tail housing off and remove the reluctor wheel, bearing and reverse gear then you can remove the reverse synchro assembly. To remove the reverse fork you will need to remove a small snap ring off the shifter mechanism. Then the fork will come out with the synchro assembly. Once you get it out you will need to gently pry the metal ring out of the hub that limits the movement in one direction. Take that ring and install it on the other side of the hub and reinstall the reverse synchro assembly with the fresh side faceing the rear of the trans. Inspect the engaugement teeth on your gear and the blocking ring. The reverse blocking ring in these transmissions are bronze and can wear out faster than the rest of the rings. I would go ahead and put a new ring in it for good measure while you have the trans down that far.
Hope this was informative enough for you to get it fixed.
Old May 31, 2011 | 03:19 PM
JrodCamaro's Avatar
Gonna have to be a weekend project at my grandpas since he's got a lift. Find these parts at any auto part store?
Old May 31, 2011 | 06:25 PM
nobird8991's Avatar
no. maybe some gear distributors MIGHT have them or can get them. or rpmTransmissions might sell them. i get my stuff from D&Dperformance.com
Old May 31, 2011 | 10:22 PM
JrodCamaro's Avatar
right on thanks for the heads up
Old Jun 1, 2011 | 07:16 AM
If you end up needing any parts just let me know.
Old Jun 1, 2011 | 07:15 PM
JrodCamaro's Avatar
Will do, haven't taken a trans out in about 3 years so this ought to be interesting
Old Jun 1, 2011 | 07:25 PM
freefallen.1's Avatar
Just FYI D and D has the cheapest online parts. I ordered once when my local distributor was out.
Old Jun 1, 2011 | 09:33 PM
JrodCamaro's Avatar
cool, thanks freefallen.1
Old Jun 2, 2011 | 12:11 PM
No problem. As someone who builds these things, I try and find the best deals to keep cost down. My local distributor is a lot cheaper when you start adding it up..lol
Old Jun 2, 2011 | 10:57 PM
nobird8991's Avatar
this is true. i drove 30 miles to a gear shop "locally" and ends up their prices were about 10% more then d&d. but i needed the part asap due to forgetting to order one thing while assembiling a trans. do what you gotta do.
p.s. trans is easy to take out. not so much to put back in tho lol
Old Jun 5, 2011 | 11:23 AM
kevindglenn's Avatar
I often have a problem getting into reverse. Generally putting it into first gear, then immediately into reverse solves this li'l problem.
Old Jun 5, 2011 | 02:46 PM
JrodCamaro's Avatar
Mine actually went right into reverse yesterday, I was astounded, the first time ever since I've got the car. I'll try this 1st to reverse and see what it'll do for me, thanks
Old Jun 5, 2011 | 06:57 PM
Dont you hate that. Thats how I found D and D. My local was out but cheaper, oh well it all worked out. I agree going in seems to be a little tricky..lol
