Clutch help needed
Old Jun 26, 2011 | 04:25 PM
gs462's Avatar
Default Clutch help needed
I tried a search and didn't find anything that sounded like my issue. I've noticed this once or twice in the past but thought it was my imigination well today I KNOW for sure what I felt, I was getting on the highway and I hammered it through3rd 4th and 5th gear when the revs got high in 5th gear the clutch pedal seemed to go soft of fall away from my foot, it was definately not right. I let off and coasted down and it was back to normal. it does this ONLY at high rpm.
Old Jun 26, 2011 | 09:00 PM
gs462's Avatar
Noone has had this problem?
Old Jun 26, 2011 | 09:19 PM
jaysan's Avatar
how many miles are on the car ?
Old Jun 26, 2011 | 09:20 PM
gs462's Avatar
75k miles
Old Jun 26, 2011 | 09:24 PM
jaysan's Avatar
did you check your fluid ?
Old Jun 26, 2011 | 09:25 PM
gs462's Avatar
No but I will.
Old Jun 26, 2011 | 09:28 PM
jaysan's Avatar
also look at where your car is parked and check for fluid . Sounds like a hydraulic issue
Old Jun 27, 2011 | 02:41 PM
gs462's Avatar
No leaks fluid is full, but it is nasty black and dirty.
Old Jun 27, 2011 | 02:56 PM
jaysan's Avatar
change the fluid .
Old Jun 27, 2011 | 03:07 PM
gs462's Avatar
Do you think this could be part of the problem
Old Jun 27, 2011 | 03:14 PM
jaysan's Avatar
yeah man there could be particles in the fluid that clog up the lines
Old Jun 28, 2011 | 03:03 PM
SPEC-01's Avatar
Do a complete flush and refill of the fluid. This is a common issue on these cars. You may want to opt for a more heat resistent fluid than stock and there are lots of available options. Also, make sure that the line that leads from the Master to the Slave is routed behind the heat sheild as it passes the header. You can wrap this line is a good protective wrap and this will help too. Give it a shot and let me know if you have any further questions. Thanks,
Old Jun 28, 2011 | 03:08 PM
gs462's Avatar
Awesome I just bought synthetic dot 3 Will this work? I also bought a syringe and I will flush it drive it flush it and so on.
Old Jun 28, 2011 | 04:42 PM
SNLPerformance's Avatar
I Prestone DOT 4 as it has the highest boiling point of non-silicone fluid that I know of. Also curious how much power you are making, could possibly be the clutch has reached it's limit.
Old Jun 28, 2011 | 04:51 PM
gs462's Avatar
Shes pretty stock, lid, cat back, skip shift, Factory LS6 manifold, not sure what else I just bought it. so I'm not sure if thats all the mods.
Old Jun 29, 2011 | 12:24 PM
SPEC-01's Avatar
Let us know the results of your flush and refill. We can proceed with more info from that point if the problem persists. Thanks!
Old Jun 29, 2011 | 03:09 PM
gs462's Avatar
Well I've drained it and refilled it 3 times went for a ride last night and it did not help.
Old Jun 29, 2011 | 05:56 PM
LS1T56FTW's Avatar
Mine took a good five times of flushing/driving a few hundred miles. The fluid is shot again, but my clutch is too now. I am going to replace all the hydraulics, do the drill mod on the master cylinder, get a speed bleeder, etc. If bleeding it a few times doesn't help out for the most part, the seals in the master cylinder could be toast.
Old Jun 29, 2011 | 06:11 PM
DAVESS02's Avatar
High RPM shifts on the stock adjustable pressure plate causes your problem. IMO the best thing to do is buy a good, non adjustable clutch from a sponsor and JUST AS IMPORTANT, take it to someone who knows EXACTLY how to install one properly. I just did a re-do for a guy who took his to a shop that wound up using the old 10mm PP bolts in the 11mm flywheel holes among MANY other things!
Old Jul 3, 2011 | 09:39 PM
gs462's Avatar
Thanks I drained n refilled it again its still dirty. Dave can you recommend a clutch kit and a shop in the Cleveland Ohio area to do it?
