LS7 Clutch
If you want something near-stock, then you can buy a Diamond Stage 1 which uses a much stronger pressure plate (non-adjustable), with a very-similar disc to the LS7. It has better friction material with the same surface area as the LS7. This kit is just $349 shipped, and you can get your stock flywheel resurfaced for $35 or so. So under 400 bucks and stronger than the LS7.
Don't get me wrong though. There are a lot of people out the with the LS7 and it works great. But on the other hand there are also a lot of people having a lot of issues with the LS7. Based on what I've read here on the forum, and my own experience, about 80% work perfectly, and the other 20% have nothing but problems. That is way too great of a failure rate.
I tried a comp stage 1 clutch and had it changed out twice because of the chattering. threw in the LS7 clutch/flywheel and it has a great stock feel for daily driving and holds up well at the track. I would recommend for a dd any day
. It takes it like a champ.
