Monster level 3 came apart....ideas?
I bought this set up used.Took a couple months for me to get it installed and lasted less then 200 miles. I was told everything had less then 1000 miles on it and it wasnt all beat up.I also put a Tick built T-56 in with an almost new slave cylinder.The master cylinder was brand new from Tick.
What would cause a clutch to come apart like this? My car is basically stock with the exception of long tube headers, Magnaflow exhaust and LS-6 intake. I didnt even get to take it to get tuned because of the drivetrain issues I have been having.
Thanks,
Chris
Thanks,
Chris
Chris
When everything is new from the start the only reason a disc would spin the hub out is from poor manufacturing. And wouldn't there be alot more damage too the other components if a problem was elsewhere? Everything else is fine.
If you were the original purchaser this would be a little different story, there is just too much gray area in the situation for me to warranty something like this.
As I said before, we've had this happen literally a handful of times, a couple of those were on us and we took care of the customer. Discs don't just fall apart, and if they do fail because of something we did it is typically within a couple of minutes of driving the vehicle, not a couple thousand miles.
If you would like to discuss this further feel free to call me, 817-750-2000.
You're fine, there is nothing wrong with the unit that you have. There are numerous things that have to occur to have this happen, most of which have tell tale signs before the disc ever gets to this point.
Keep in mind that this has happened to ~ 0.00125% of all the Monsters we've sold.
![Happy](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_stretch.gif)
Also, keep in mind that the clutch the OP is discussing is over two years old and was purchased second hand.
Really? We have a handful of issues out of over 4,000 clutches sold and that scares you?
Keep in mind that this has happened to ~ 0.00125% of all the Monsters we've sold.![Happy](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_stretch.gif)
As I stated above, everything was new when the orginal purchaser installed it.And I made sure I had a new pilot bearing installed when it was installed into my car, that is just common sense.Along with a new rear main seal.
All I orginally asked is why the disc came apart, you seem to have an issue with following this thread trying to come up with excuses on why it came apart.It came apart and it is simple as that, just look at the pics.I put less then 200 miles on it since the install and had to have to towed to my house.
This is not my first dealings with a clutch that has came apart but this is my first and last dealing with Monster clutches.I am aware things happen but dont put the blame on everything else that could go wrong when everything was installed new from the beginning.
No one should be scared to use your products, but when you see multiple threads with Monster clutch issues you need to tread very lightly on how you handle the situations.Remember I said "bad news travles faster then good news" on the phone?
Thanks,
Chris
