Clutch and transmission issues. Will not shift jumping out of gear, all is NEW HELP!!
So last week I finally got my car back after a brand new motor, Monster stage 3 clutch, and rear diff were installed. I have less then 250 miles on this new setup and have stayed under 3500 rpms and have been babieing the heck out of it for break in.
So last night I decided I wanted to see at least alittle of this new power and took off as normal inn 1st but once I got going hit it about 60% to 4K rpms and hit it good into second. Got ALITTLE tire spin (not much at all) and it didnt feel right. I hit it to 3rd about the same way and grinded going into gear and the power just wasnt there. Car bumps out of gear??? I try to go back into 3rd and no go. Cant get into 2nd either, I then try to get back 3rd and it wont happen. I finally get 4th and cruise the 1 mile home. I get to the light and coast to a stop in nutral. I have to fight it into first and just drive the few hundred yards to my garage. I try to drive it today after posting up with some ideas. Car fights 2nd and I stop and try to hit all the gears standing still. With the car stopped in nutral it wants to push alittle forward??? I can get 1st but second is not a option. I finally get it into 3rd and the shifter gets STUCK. I mean I cant get it out with car on or off? I am pulling hard on it to. Finally I decide to use my left foot to rock the car, my right to push in the clutch and it finally comes out.
Now I am thinking I need a new slave, master cylinder, or the slave shimmed. Not sure where to start.
If the transmission is stuck *IN* gear then it is a transmission issue. When you went for 3rd and got blocked out you might have broken a synchro key. This is a very common problem with the T56 transmission. Since you just got the car back from having a clutch installed the rest of your problem sounds like your hydraulics needs bled really badly.
