T56 vs TKO600, 7k shifts, 2700 lb car
Just looking for opinions.... not a huge difference in price so might as well do it right the first time. Going in a 92 mustang coupe, lq4, l92s, vic jr 7k shifts
A T56 with triple cone synchros will shift out beyond 7K.
Rockland agrees:
http://www.rsgear.com/products/trans...dge-viper.aspx
A good clutch can make/break your RPM capabilities also.
Rockland agrees:
Faceplating does not make the transmission clutchless...
http://www.libertysgears.com/faceplate-proshift.htm
I always use the clutch at part throttle....never at full throttle. Breathe the throttle a bit to unload the tranny and pull the gear.
Rockland agrees:
Rockland agrees:
If this is a drag race application, you will not out perform a face plated shift design. It will shift 7K with ease and will only take a slight side step of the clutch to make the shift. If you use a kill box in conjuction with a face plated trans, you can literally hold the throttle to the floor and row gears like a pro!
A GTO T-56 (2.97 first) isn't really an option for faceplating because of the triple double design leaves no room. Tremec did make a trans with this ratio not for production cars but has the 10 spline input in a double/single that can be faceplated. The standard 2.66 ratio f-body T-56 will faceplate no prob.
