4th gear grind after Tick MC and mobil 1 ATF
I just installed my Tick MC and all the gears go in and out much smoother than before, however 4th gear grinds. It has always had a slight scratch/grind at high rpm, but I blamed the stock MC on that after doing some reading. Now the scratch/grind seems to be worse than before. I bench bled the system before I put it in, but still have yet to bleed it after the install. I'm sure there may be a little air in the system but not sure this is the problem as all the other gears work smoothly. It does this both on the 3-4 up-shift and 5-4 down-shift. Only other variable is that I changed the tranny fluid to Mobil 1 ATF a day before I did the MC, but never did any high rpm shifting so not sure if this had a negative effect. Possible air causing grind from not engaging clutch all the way? Time for rebuild? Synthetic ATF causing it to act up? Any help would be appreciated! thanks!
![Sad](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_sad.gif)
Its strange because it used to occasionally grind going into 3rd gear, but after MC install it doesn't at all.
