High HP 6 Speed cars what you have? 800-1000HP
Just wanna see what people with high HP are running. I just got a 01 T/A that is suppose to have a tick stage 2 t56 in it. So im curious what trans/ upgrade/ clutch you are running if you have some big HP. Im building a 6.0 single turbo 80MM and aiming for 800-1000 hp. Street car, that will occasionally visit the strip.
At a 1000 hp I don't care if God built it, you are going to need a oil pump system and a larger 30-31 spline mainshaft in it for it to hold up. A properly set up correct style clutch is a must as well.
With 800, you can probably get away without a pump depending on a few other factors but you will need the upgraded mainshaft in it.
