t56 wont go in gear
02 z28 with a t56 just rebuild th motor put it back in the car with the tranny and when the cars off it goes into all the gears no problem as soon as i start the car its like the shiftier locks up in neutral i can start the car in gear but once i start moving and try to shift i get nothing i tried bleeding the slave and still got nothing.. ANY IDEA SO TO WHATS GOING ON??????????
Just some friendly advice, PLEASE USE PUNCUATION because your post is very hard to read comprehend and folks will be much more inclined to chime in if its better structured. Also please allow longer than than an hour and a half before bumping.
Sounds like the age old clutch drag issue from what I can gather from your post.
