How to prolong the life of your clutch
#42
Basically you are just trying to get the heat out of the clutch/transmission because it will help maintain and extend the life of everything.
__________________
Glenn ***
Sales Tech
www.bmrsuspension.com
813.986.9302
Find a Quality alignment shop near you!
Glenn ***
Sales Tech
813.986.9302
#44
Well i can say that if you have been seeing what others are doing with the C7 z06 and all them are having issues and putting in other clutches etc.
I did this mod to the '15 and regularly blow it out after a hard track day and I have about 10+ 1.4x 60' and still going strong with over 710RWHP and 720RWTQ. 3700lb race weight.
Jeremy
Jeremy
#45
Jeremy
Jeremy
So for a 98-02 F-Body Bellhousing you recommend 3 holes starting on driver side going down to the bottom of the bell housing, just like the picture you posted here?
Do you recommend another hole going towards the passenger side as well and what size 1" or 1.5"?
#46
Can anyone post before and after pictures? Seems many have tried it, but we only have microsoft paint images of where to put holes or something. Wanting to try this with my 01 camaro to see if it will help a sticking pedal possibly.
#47
I'd look for other issues first on the sticking pedal including adjustments to the clutch pedal throw. If the hydraulic system is fairly old it may be time for new slaves. Is your clutch fluid clean? If not, that's the first thing I'd address with a system bleed or the "ranger clutch protocol" (google it). I service my clutch fluid every 1K miles, not that it necessarily needs it.
