monster stage 3 clutch kit
The holding power is great,But it does not like to be slipped..With bolt ons theres no need to slip the clutch because you haven't moved the the torque of engine from low to higher in the curve as you do with a cam..
If you daily drive your car in traffic and have a decent size cam don't waste your money on a level 3...the clutch will start to squeal like a stuck pig because it gets glazed and i don't care how much you launch the car hard to get rid of the glaze it will come back..I can't stand it,makes my car sound like a pos...save your money and buy something better.
If your clutch is chattering I'd look into it, call me and I'll be glad to go over a few things. We've sold literally thousands of these, there is a reason the noise is there.
Call me - 817-750-2000
O.P. the Level 3 will take some incredible abuse, it will drive great considering the power level it will hold and the pedal effort should be roughly 8% stiffer than stock, most say it feels the same. If the pedal is stiffer than that take a look at the hydraulics of the car, or, just give us a call and we'll get you taken care of.
If the clutch is squealing it's because of being glazed excessively. This is caused by a couple of things, either fluid contamination or driver error. I daily drive a GTO with a heads/cam package and stock gears, the car has terrible bottom end power and my clutch doesn't chatter or squeal, and it's got 100+ track passes and over 30k miles on it.
