clutch or master cylinder issue?
Im going to get my trans built, it chatters, and goes into gear very roughly. Under hard acceleration it either wont go into gear at all or it grinds, like your trying to shift without using the clutch. The clutch pedal gets real soft and squishy and wont go into gear unless i pump it a few times.
The clutch is stock with 63k miles on it. Grabs fine, doesnt make anysounds, it uses the stock hydrolics.
Should I get a new master or look into a clutch kit with my rebuild?
http://www.tickperformance.com/tick-...camaro-firebird/
http://www.tickperformance.com/1993-...camaro-trans-am/
