wire plug removal for clutch pedal sensor
I am trying to adjust the clutch pedal sensor and in order to turn it I need to remove the wire plug. This is probably a stupid question but whats the trick to getting the plug to come out? Its the same style plug as the brake pedal wire plugs, there is a plastic "door" that has tabs on either side of the plug that can be popped off, but do not seem to aid in actually removing the plug. The plastic seems brittle and I don't want to crack anything. Thanks in advance, Alex
