Clutch & Q/T 8020 issue
Ive got an issue with a b@$t@rd set up. Ive got a 93 t56 that Ive swapped over to a LS1. Ive put over 3k miles on it with no problems. I put a Quick Time 8020 in it and problems ever since. I had to mill .400 off the input shaft before I had clearance just to be able to freely turn a slide yoke once bolted up. Now when I push the pedal in and try to put it in gear it tries to take off. No problems before the q/t install. I know it is something simple but Im drawing a blank. Any info?
