T56 removal from bellhousing
I am new to the ls/T56 stuff and I need a to remove my trans to have snyconizers replaced in 2nd gear. I was wanting to do this without removing the bellhousing, clutch and etc. If someone had a step by step process of this it would be great!!
You just unbolt the shifter, and if iirc unplug the 3 plugs on the driver side of transmission and 1 on the passenger side,quick disconnect the line to the slave, remove driveshaft and u bolt that tranny! It's as easy as any other rwd car I've pulled a transmission on.
