Pilot bearing direction...
Your picture #1, which is the side where you can see the inner and outer bearing races, is the side that goes toward to crank. The closed side(#2) goes toward the trans.
Side #1 towards crank, #2 towards trans
https://ls1tech.com/forums/13649428-post10.html
https://ls1tech.com/forums/manual-tr...k-does-go.html
https://ls1tech.com/forums/manual-tr...g-bearing.html
