Pilot bearing- how far into crank does it go?
I have an 04 LS1 from a GTO and a T56 from 02 camaro. Just put in the pilot bearing- right now its flush with the crank, but i see it can be driven in further. I have a corvette GM shop manual, but it just states "install pilot bearing". Did a search, but no luck. The was no bearing in the crank when i got the motor, so i had nothing to go by. Does the bearing need to go in further to keep the input shaft from bottoming out on the end of the bearing?Thanks- Scott
Flush is where it should be. You just wanted seated well, whether it is in a little further or not doesn't make a difference - you have some leeway with the input shaft - just don't drive it in too far.
Umm i think this is all wrong.
The fbody transmission has an input shaft that is half an inch longer (at least than my CTS-v t-56)
I have an Fbody ls1 and put the fbody pilot bearing in (about an inch across) and it fits in the smaller hole that is further back.
I had to tear the whole thing back apart because apparently I have to use the pilot bushing which is the one that is about two inches across and sits flush with the crank.
I think the GTO's are the same if I am not correct and if you are using the f-body trans with the longer input shaft you may need to pull that bearing out and put the smaller bearing in further back.....
What is the best way to install a needle bearing pilot bearing like the one on the F-body T56? Just a hammer and a socket? Won't that distort the damn thing? I know I have done that before and it really needs a lot of hammering to get the damn thing in there!
