02 camaro T-56 getting hard to put in gear
Location: Shreveport, LA (originality from Columbus, GA)
i have a stock (including clutch) 02 SS with almost 112,000 miles on it and its getting hard to put in into gear....mostly 1st and reverse, but get some trouble out of all the lower gears sometimes. i have started having a hard time at stop lights getting into first from a sit still, and if i stop to back into a parking spot its real hard to get into reverse. i was gonna drive the car today but i couldn't even get it into reverse to get out of my driveway. like i said, its a factory car i bought from the original owner early this year so im sure it still has the original clutch in it. i have had someone say they think the clutch or pressure plate has gone bad, and some others think its the master or slave cylinder. anyone have an idea what this problem is or should be?
bleed the system make sure all the air is out. when the car is off is it easy to shift into all gears it should be. if not there are problems with the trans. if all the air is out of the system it all should work properly. bad clutch will slip meaning you can put it into 5th or so stop on it and it should bog down. pressure plate i have no idea it all swaps out with a clutch kit. master or slave good luck. but i do have two masters if you looking to buy both have drill mod More fluid pressure for a bigger clutch and one new one 47,000 miles pm if intrested
i was able to get the trans to go into gear last night fine with the car off, but while it was running it was hard. master cylinder is full....guess im going to be doing a clutch upgrade as well as the master to a tick.
