resurfacing the flywheel?
Old May 18, 2012 | 01:22 AM
GiggleJuiced_SS's Avatar
Default resurfacing the flywheel?
so after a night at the track, my 80k mile clutch is on its last leg. i think when it was breathin from the dark side of the moon really killed it so i was lookin at putting a centerforce or ram clutch in it. my question is, do i need to get the flywheel cut? i dont think it needs it but i wont know for sure til i pull it out. its my daily driver in the summer so i cant have sitting while the machine shop cuts the flywheel. also i guess it would be a good idea to replace the slave cylinder? and install a shim?
Old May 18, 2012 | 01:37 AM
Ferocity02's Avatar
The flywheel should be resurfaced since it breaks in with the new clutch. If you have the money you should replace the slave. I think you can get them from Autozone for like $70 and they are made by AP, the same people who makes them for GM. You will need to measure to see if you need a shim. So to avoid downtime you could buy a shim set so it's ready in case you need one.
Old May 18, 2012 | 01:41 AM
i see alot of ppl buy a .500 shim does that sound about right? i was lookin to upgrade to like a ram slave cylinder over stock, my buddy put one in his gto works great. mine doesnt have alot hp right now, but hoping to in the future.
Old May 18, 2012 | 02:13 AM
Ferocity02's Avatar
The shims are usually under 1/8".
Old May 18, 2012 | 05:44 AM
nascarnate326's Avatar
Just get a new one or a new re manufactured flywheel. Cost me $50 from advanced auto with a coupon code for a new re manufactured. That way your not playing with shims etc.
Old May 18, 2012 | 06:41 AM
LS1-450's Avatar
yes, resurface flywheel or replace it. shim what?
Old May 18, 2012 | 06:56 AM
BOBS99SS's Avatar
Captain Double Post
If ya can afford a tick master it is worth every damn penny, its a must have part for these cars, the machine shop shouldnt have it for long at all just get it done locally if ya can, shops around here charge 50 to 75a to have it done
Old May 18, 2012 | 10:26 AM
Ferocity02's Avatar
You should also get the flywheel and pressure plate balanced as a unit.
Old May 18, 2012 | 11:33 AM
SPEC-01's Avatar
Agreed! Resurface (or replace the flywheel), balance the assembly, and check the stack height to determine if you need a shim. That should cover you!
Old May 19, 2012 | 10:14 AM
anyone running a ram clutch setup? seems to be a great deal for the $$
