Monster Clutch Twin Discs-Released!
#43
I don't see how a stock slave would work with this clutch, since it uses a flat diaphragm spring. In the picture that was posted there are marks on the spring (assuming from the stock bearing) and the bearing contact is way out from the tip of the fingers.
This clutch needs a radius faced bearing that makes contact as close to the tip of the spring as possible, and the bearing probably only needs .250-.300" of travel to achieve full release. But I am sure that Monster knows this....
Andrew
Andrew
#44
Andrew
Andrew
The unit requires considerably less travel than that to release, but yes, we're very aware of what you pointed out.
#45
Let us know if you have any other questions.
#46
So as promised, here is the clutch. It just came in today. Pretty nice piece. It's almost a shame to install it. :-(
Anywho, I do have one question to SNL.
The last pic, the bolts are of different lengths. I'm guessing that the shorter ones go to the spots that have more thread, due to the boring for the alignment holes. I just want to make sure as they were not installed in any order as I had two long ones next to each other.
I am also curious if a piece with sprung hubs will be offered?
#50
Is it common for these to require a steel alignment tool?
I'm using the plastic one and the having alignment issues. Just did a DD install on my dodge diesel and ended up taking out the input shaft and using it as an alignment tool. Seems the DD clutches are much harder to align then the single discs.
#55
Thank you Monster for the stage 2 twin. I have 2000 miles on it and it feels great. Been to the dyno and put down 775 rwtq, and 690 rwhp. It held no problem and I love it on the street manners. I put 50 mile a day on it half freeway and half downtown stop and go driving. This thing has been the best clutch i have had bar none.
#56
Well my Stg 3 has 7K on it & still goin strong but I am planning for that day............I have went to the website but do not find the twin disc prices for the F bodies?If I do a search for twin disc it brings it brings up Stg 5 kits ?
#57
You can order the better McLeod clutch kits here.
http://www.coloradospeed.com/flywhee...s1-p-5317.html
http://www.coloradospeed.com/flywhee...gt-p-7061.html
http://www.coloradospeed.com/flywhee...s-p-40911.html
http://www.coloradospeed.com/flywhee...s-p-41015.html
http://www.coloradospeed.com/flywhee...s-p-41018.html
http://www.coloradospeed.com/flywhee...s-p-41019.html
http://www.coloradospeed.com/flywhee...t-p-41023.html
http://www.coloradospeed.com/flywhee...s-p-41022.html
http://www.coloradospeed.com/flywhee...gt-p-7384.html
http://www.coloradospeed.com/flywhee...ls-p-6543.html
http://www.coloradospeed.com/flywhee...ls-p-6906.html
#59
Monster Twin Disk ****
I'm just going to leave these here:
http://www.flickr.com/photos/74632166@N04/7940692916/http://www.flickr.com/photos/74632166@N04/7940692916/ by http://www.flickr.com/people/74632166@N04/, on Flickr
http://www.flickr.com/photos/74632166@N04/7940688776/http://www.flickr.com/photos/74632166@N04/7940688776/ by http://www.flickr.com/people/74632166@N04/, on Flickr
http://www.flickr.com/photos/74632166@N04/7940684162/http://www.flickr.com/photos/74632166@N04/7940684162/ by http://www.flickr.com/people/74632166@N04/, on Flickr
http://www.flickr.com/photos/74632166@N04/7940679934/http://www.flickr.com/photos/74632166@N04/7940679934/ by http://www.flickr.com/people/74632166@N04/, on Flickr
http://www.flickr.com/photos/74632166@N04/7940676472/http://www.flickr.com/photos/74632166@N04/7940676472/ by http://www.flickr.com/people/74632166@N04/, on Flickr
http://www.flickr.com/photos/74632166@N04/7940673308/http://www.flickr.com/photos/74632166@N04/7940673308/ by http://www.flickr.com/people/74632166@N04/, on Flickr
http://www.flickr.com/photos/74632166@N04/7940669750/http://www.flickr.com/photos/74632166@N04/7940669750/ by http://www.flickr.com/people/74632166@N04/, on Flickr
http://www.flickr.com/photos/74632166@N04/7940666054/http://www.flickr.com/photos/74632166@N04/7940666054/ by http://www.flickr.com/people/74632166@N04/, on Flickr
http://www.flickr.com/photos/74632166@N04/7940663018/http://www.flickr.com/photos/74632166@N04/7940663018/ by http://www.flickr.com/people/74632166@N04/, on Flickr
http://www.flickr.com/photos/74632166@N04/7940658516/http://www.flickr.com/photos/74632166@N04/7940658516/ by http://www.flickr.com/people/74632166@N04/, on Flickr
#60
No fair....I think your is greener than mine. :-p
Edit: I've also got mine installed. I have yet to drive it (due to my exhaust not fitting from other changes made) but I am using a 5/8" wilwood M/C instead of the usual 3/4 or 7/8 that most use for the RX-7 swap and I must say...me likey the pedal. It's softer than what I had. I had talked to Steve about whether the fluid volume of the 5/8" was enough or not and after measuring the throw we decided it would be fine. And it was!
