prestone dot 3 to 4 swap?
What's the best way to Exchange to dot 4? Do I just buy a quart of dot 4 and run whole bottle thru system? Or is there a better way to make sure its got all the dot 3 out?
you can suck remaining fluid out of the resovior and top it iff and then bleed/flush the system - it needs to be done periodicly anyway. be forwarned its kind of a PITA to reach the bleeder 14mm medium length 1/4" drive -if you havent done this before and dont let the resovior run dry you will have to start over.
