Flywheel for a McLeod RST Clutch
I'm going to buy a McLeod RST clutch for my 546rwhp C5.
http://speed-eng.com/store/mcleod-se...o-p-10227.html
$689.99+free shipping
My biggest concern is the flywheel. According to the McLeod website, the RST must be used with a LS1 flat style flywheel. Will it work with an 12571611 LS7 flywheel?
http://www.mcleodracing.com/products/RST+Twin+Disc.mcl
"Needs LS1 Flat style flywheel with this application."
If the LS7 flywheel doesn't work with the McLeod RST, what is the part number for the LS1 C5 flywheel?
Could/should I use a billet steel Spec LS1/LS6 flywheel ($233.10) with the McLeod clutch?
http://www.tickperformance.com/spec-...-ls6-flywheel/
I'm also planning on purchasing the following. Does this look like the right set-up?
Tick Performance Remote Clutch SPEEDbleeder Line
http://www.tickperformance.com/tick-...to-ls1-f-body/
$49.99+$6.75 shipping
