tr6060 connectors
Old 08-12-2012 | 12:58 PM
shelbycob's Avatar
Default tr6060 connectors
i plan to use a new tr6060 in a project car, but want to know if you can buy a connector that will plug into the factory quick connect on the outside (or on the slave cylinder), that i can then plumb into an AN fitting. I know i can cut the hardline, and tig an AN fitting there, but prefer to find an aftermarket connector if possible
Old 08-12-2012 | 08:05 PM
74modified's Avatar
I have been looking as well. I think Tick makes a complete setup, but I want to do it myself. I wonder if anyone has cut the line and flared it?
Old 08-13-2012 | 08:35 AM
shelbycob's Avatar
if i cant find a connector, then flaring or tig is the next step. I can buy the GM hose, and cut off the master cylinder connector, but that seems a little messy
