Installed a Monster Stage 2 and Tick master today.
Well, not just today, but over the course of the last month. Such a pain in the ***. Not terribly complicated, just a lot of dumb **** going wrong. With it being a garage queen, I didn't rush it.
I didn't have any trouble bleeding it with the remote bleeder. It gravity bled itself. It was slow, but it worked just fine. Adjusting the master cylinder was very straight forward.
The clutch pedal has a very short travel and is noticeably stiffer. It drives and shifts smooth, so I assume the short, stiff pedal is acceptable. I look forward to romping on it after the required 500 mile break in.
I'm very happy you are pleased with your install.
I think a lot of people look for an aftermarket clutch that engages further out like the stock clutch does and a stock pedal feel.
While this is a comfortable set-up for doing anything in town, I just don't prefer it. I would prefer and like a pedal that has a shorter travel(not extreme) and that releases closer to the floor than the stock pedal(again not extreme). This sounds a lot like what you have achieved.
Every clutch will be different though in release and pedal feel. I try to recommend to people to find a buddy or someone local with an aftermarket clutch of different brands to feel out for yourself.
I can't give an honest assessment of the clutch at this point because I have to baby it for 500 miles. I drove it to church today and I like it for normal driving. The clutch pedal is definitely stiffer, but not terrible. The short throw of the clutch pedal feels more positive, no slop. It is still easy to shift smoothly. I was concerned with the short travel of the clutch pedal I would have problems with grabbing, stalling, bucking, or jerking. I look forward to some aggressive driving. I have had no chattering.
I'll chime in here on my experience with the Monster Stage 2 (I also have a Tick). So far, it's been a great clutch. Have probably about 2,000 miles on it, and it hardly chatters at all anymore. I think when it does chatter it is more my fault for not giving it more gas. It gets grabby when it gets below about 1-1,500 rpm and starts to chatter a little--not much.
It chattered a good bit in the beginning, but over time it has died down. I was very strict about making sure I drove the 500 city miles before getting on it. I even waited past 500 miles because I took a long highway trip somewhere in there that I did not count the miles for.
My pedal is stiffer and the height is lower, but I like it. You have to get used to it, but you will appreciate the positive engagement feeling it has after you drive it a while.
I've got a stage 2 in my 3rd gen swap and I really, really like this clutch. Its easy to drive without being annoying, and when I finally went to the strip last week it never even flinched after 5 passes and 5500rpm launches. Wicked, reliable engagement and 1.66 sixty foot times with a bog since I don't have enough power. Its fun having more driveline than engine...
Today I drove the car to work. It drove very nice both ways except for a minor issue. I am having trouble shifting into first. I am not sure if it is air in the system or the master cyl needs adjustment. All other shifts are smooth. I found from a stop, if I shift into second then first it was smooth.
Happy clutching!
oh no
put a monster stage 2 in mine.broke it in....over 800 miles.Gets threw all the gears at high rpm easily.which was the problem i was trying to correct.unfortunately it keeps slipping.i'll have the car floored and the rpm needle will stay in the same"orange spot as my speed gradually increases.by the time i get into fourth and it grabs i've lost about 700 rpm and i should be at 110mph when i'm at 100.oh and i'm only pushin' 415hp at the motor!!!?
Give us a call or shoot me an email and we'll go from there.
Monster stage 2 review
two things....first i broke that plastic cover on the bell housing when i did my install and never replaced it(on the driver side almost opposaite the starter)second i found a power steering leak pretty much directly in line with that cover(which may explain the high rpm slipping)so i replaced the cover and bled the clutch,went and made four 1/4 mile runs.The slippage was barely noticeable,worse on the last run but hopefully this will just go away over time now.I bought this clutch because i kept getting locked out of gear on runs and did'nt know why.I can tell you now that your stock clutch is the reason.I've done about 15 gear mashing 1/4 miles and havent missed one shift.Oh and no spongyness after any of the runs.I have a loud mouth exhaust so if there is chatter i'm not hearing it.So yeah...pretty happy after 800 miles.
I'd empty a whole can of brake cleaner inside the bellhousing, with the engine idling and someone holding the pedal down. that should clean that **** off.
Id used 2 cans personally..
the Stunna
the Stunna
Glad you can get through all the gears now Jim. That stupid freaking GM self adjusting pressure plate. We have been waiting how many years to figure out it's the pressure plate that was locking us out of gears at high rpms?
I've been on my soap box lately about everyone jumping on the "you need a new slave, you need a new master" band wagon and it needing to stop. I've been on this site for four years now and I can't recall one time replacing the slave or replacing the master cylinder has cured the "locked out of gear at high rpm" syndrome.
On the other hand, I've seen countless threads started about being locked out of gear at high rpm where everybody tells them they need to replace the slave, and if that doesn't work they need to replace the master. Well, the person does both, just like me, just like Badamn, just like every other person and they still having shifting problems (with the stock clutch).
Badamn and I were both getting locked out of gear at high rpm. Replaced the slave...nothing happened. Replaced the Master...nothing happened. Did the drill mod...nothing happened. Now Badamn gets a stage 2 Monster clutch and is banging gears at red line flawlessly over and over with the stock hydrualics. I think it's about time Ls1tech evolves past the "replace the slave and replace the master" stage. It might fix someone's general shifting problem they might be having due to a failed unit, but is not fixing the high rpm shifting syndrome everyone has with the stock clutch. It's the stock self adjusting pressure plate!!!
Like I said on the phone, I suspected a fluid contamination. Let me know if you need anything else!
