A4 to m6 help
Derek
- t56 Transmission
- t56 bellhousing
- clutch kit (pressure plate and friction pad)
- flywheel
- master cylinder
- slave cylinder
- pilot bearing
- shifter assembly (shifter and shift ****)
- upper console (w/ boot)
- manual style pedals
- vehicle speed sensor and reverse light pigtails
- m6 PCM or have yours flashed for an m6
yes you can have any tuner flash it to a 6 speed tune
the one decision you'll have to make is with the wiring. you can rewire the factory 99 harness for the manual and have it flashed (pretty easy), swap in all the 98 stuff (which is a step backwards with the slower PCM), or use the 98 wiring but convert it and use the 99 computer reflashed
A word for the wise though, make sure to get all new hydraulics, M/C, Slave etc. I'd recommend a tick m/c to be safe and by all means dont use the old clutch from the 98 get a new one. It may cost more coin up front but it will save you some headaches sooner or later.
