t56 f-body shifters - what's best
I agree with brigade. I have the hurst billet with the handle and **** out came with. When I got my car it had the factory one with a short stick. I hated that and can't see how anyone likes them. I always felt like I was reaching down in the boot to find the shifter. But to each their own. Anyways I really like the hurst. FWIW, I was adjusting the stops and drive the car around a few times without the console. I liked this the best because I had room for my elbow and didn't haves to worry about it draggingacross the console.
That's exactly the way I did it, drove around without the console. I liked it so much I am now console delete and just fabbed a nice piece of walnut where the console was and attached a Super boot to that. By the way I have a hurst Billit Plus w/ chrome stick and an old white 4/speed ball. At a car show somebody ask me why I took the 6/speed out.
hey fst ss you still out there?? finally got almost all my bugs out did you do the teamsters car show this year?? shoot me a p.m. with your number. i need to talk to you about your tuner. tell earl to kiss a hairy dogs butt will ya? the oldman...
I know this is an old thread, but I have a question. Im putting a T-56 in my truck, and this necessitates a longer stick. So Im looking for a shifter that has the shortest throws, so that by the time I put an 15" stick on it I dont have a foot of throw. So, whos shifter has the shortest throws?
OK, this post is even older now but I have a little problem with my MGW. The Warhawk has been up on a 4 post lift for about a year, so when I let it down yesterday and cranked it for it's yearly drive around the block it won't go into reverse. I don't want to be rough with it but it just won't go way right. Any ideas??
#37
grb
if just reverse is hard to get into maybe the reverse lockout solenoid, or wiring to it, is bad
IDK about the MGW, I have the Hurst Pro Billet which for me I really like
You can verify you don't have a disengagement issue by jacking up rear end, start car, with clutch pushed all the way down and in gear do the rear tires move?
If so you have a disengagement issue preventing you from going into reverse....although typically this would also be 1st gear also which is why I asked about that
If disengagement issue, bleed clutch hydraulics. Maybe with the car sitting for long periods of time the seal in MC may be getting bad
#38
Shifters in 4th Gen:
Stock - horrible feel and sloppy, they are all better
SLP - slightly better than stock, less slop, inexpensive upgrade to stock
B&M - pretty decent. Tighter, doesn't pull to center the way I like. Fair price for good shifter
Hurst - pretty decent, tighter, better feel than B&M, doesn't pull to center the way I like, inspired confidence in normal driving. Fair price for good shifter
Pro 5.0 - tight, excellent feel, no slop, noisy, perfect pull to center the way I like, best of the lot for fast secure 2nd to 3rd shift, inspired confidence in all driving conditions. Outstanding price.
MGW - expensive, good shifter, disliked the offset, drag racing like the Pro 5.0 better due to 2 to 3 shift.
#39
Out of curiosity, what fluid do you use?
#40
