McLeod RXT Flywheel Question
I'm in the process of putting a Rxt in my 02 ws6. I ordered it with the steel flywheel.
Here's the problem: the flywheel engages the starter gear when bolted down. Engine won't turn.
I checked the invoice and it says I received the flywheel for a LQ4. I'm assuming I was sent the wrong flywheel. Will the LQ4 flywheel fit a LS1 block?
