Different T56 Clutch Line Quick Disconnects?
I'm installing a Viper T56 behind an LS3 in a '68 Camaro. I've got an LS1 hydraulic hose with the quick disconnect that mates perfectly with an LS1 slave cylinder. Because the Viper slave cylinder mounting holes are clocked differently than the LS1 T56, I'm using a Viper slave cylinder.
I can't get the LS1 quick disconnect to latch into the Viper slave cylinder quick disconnect. I can feel the mating surface in the connector on the slave give as I push the hose fitting in, but it just won't latch.
So, my question: Are there different configurations of quick disconnects between the Viper and the GM T56s, or am I just not pushing hard enough?
I don't know this to be absolutely correct, but I believe there is a roll pin that holds the "quick disconnect" in place in the master cylinder, which is why it doesn't "click". Assuming you didn't discover this already since the post is over a month old.
