vette master cylinder and f-body t56 questions
Old 09-29-2012 | 05:33 PM
K11PER's Avatar
Default vette master cylinder and f-body t56 questions
So I was not paying attention a couple months ago when I bought a BNIB LS6 master cylinder and surprised myself today opening it up not seeing what I thought was an f-body master.
I have a stage 2 t56 from a f-body, and a vette master that came with no line to the slave or reservoir. Can I still use this? I have a spec twin disc clutch. Its going in a chevy s10
If so, does anyone have a part number/link on the line from the master and for the reservoir? Budget is pretty tight, I don't have money for a tick yet, I'll change that later down the road.
Thanks,
Kevin
Old 10-02-2012 | 11:29 AM
K11PER's Avatar
bump anyone?
Old 10-02-2012 | 09:36 PM
Jonathan@Tick's Avatar
LS1TECH Sponsor
If you can figure out how to mount that master, then we can probably set you up with a line. We have used f-body master lines that I think will work or we could set up up with a new line if you need a different length.
Let me know if we can help.
