ls1 4l60e to t56 swap I need help with cruise control
alright i did a 4l60e to t56 swap a year or so ago in my 99 z28 and havent had cruise control since. I know there is a write up but the only one i can find is a lt1 car and its different. thanks alot
I'm in for results here also. On the clutch anticipate switch theres 4 wires. I know that 2 wires on the anticipate switch go to the brake cruise switch in series. Then one wire goes to ground and another has to be run to the pcm. However I havent seen anyone do this so im wondering as well.
