bell housing dowel pins
Those bell housing dowel pins definitely come out. The easiest way I have found to get them out of the block it to use a long punch and hammer them out towards the back of the block.
__________________
Glenn ***
Sales Tech
www.bmrsuspension.com
813.986.9302
Find a Quality alignment shop near you!
Glenn ***
Sales Tech
813.986.9302
Were you able to remove them? We have heard of people doing this, and if I remember correctly one guy even cracked the block.
__________________
NOW OFFERING TSP BY YANK CONVERTERS
COMP - FAST - PACESETTER - WISECO PISTONS - LUNATI - CALLIES - NEW TSP BRAND CRANK & RODS - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - ARH HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - PRECISION INDUSTRIES - YANK - CIRCLE D - AND MORE!
NEW NUMBER (512)863-0900
If hammering them out doesn't work I would either spray them down with some sort of lubricant and try to work it out slowly or use a small propane torch and heat up area around the dowel pin and it should be a bit easier to get out.
__________________
Glenn ***
Sales Tech
813.986.9302
Glenn ***
Sales Tech
813.986.9302
I am not too sure what you mean that the block is already busted? But if the block is already a boat anchor just cut a slot in the block with a die grinder and they will fall out, if you don't want to that, it's time for a bigger hammer.
