View Poll Results: Which clutch for drift car
Monster lvl 1 twin
3
50.00%
Spec mini twin lvl 1
0
0%
ACT TS01 street/street disc's
0
0%
Mcleod RST with YT flywheel
2
33.33%
Something cheap and replace later
1
16.67%
Voters: 6. You may not vote on this poll
Clutch talk
Clutch talk
I'll start this off with a little on the car, its not a drag car, its weight is 3000lbs, will eventually make 550hp to the ground (400 now) and its my drift car so the clutch see's a lot of abuse. I want the moi to be low and would like the lowest weight possible for the money. The 2 year warranty on the monster seems like itd pay for itself in my case. If I just buy a $500 stage 3 type clutch, then it'll probably need replacing after one season, thus equaling the cost of the monster
Options are in my preferred order at this point.
1. is $1200 with a speed bleeder and two year warranty!! I assume it to be the 2cd lightest option from talking with the rep and rebuild able. Not a fan of stock pedal feel though.
2. is a bit more pricey but the lightest I have found. No warranty. Before you jump on the spec sux wagon, Ive got 40K miles on my current but toast Spec 3+, with lots of racing and drifting.
3. because Ive always loved ACT's in my honda's and the pedal feel was insane!! I like a good stiff pressure plate. It looks to be heavier than the other two, not rebuild able?
4. Probably weighs the same as the ACT with the yella terra or ACT flywheel. This is the cheapest option @ $970
5. Can do a stage 1 ACT, spec 3+ again, monster lvl 1 and save some weight just with the flywheel.
What master is in the car? Pedal feel with our twin will be more like stock with a stock master. If the car has a Tick master it will be stiffer and that may be what you are looking for. Give us a call if you have any questions about our twins
If I do a full size clutch it'll have to be the ACT street (rated @ 725ftlb) and fidanza aluminum flywheel to shed some weight. Pretty good deal on that flywheel at 12.5#'s and replace able friction plate for $300.
I am running the stock master. I just drove my buddies hawk at lunch (said he thought his clutch was going out cuz he kept missing 3rd) and my 3+ definitely has more pedal pressure than his LS7. I flat shifted his car 1st to 4th 4 times back to back, no issues.
Jenson, Our kit has 120-day warranty. It is infinitly rebuildable and can even be upgraded to a triple-disc in the future if you ever need that option.
That being said, your power level doesn't necessitate a multi-disc so you could opt for an Aluminum pressure-plate version of our single disc (Stage 4 would be a great option) and our aluminum flywheel too. Let me know if you have any further questions. Thanks,
Our lightweight twin weighs in at 34 lbs with a MOI that is lower than anything you're referencing in this thread. It comes with a full 2 year warranty regardless of how it's used and is easily rebuilt for $499 - which also restarts your 2 year warranty.
When you look at it, you can't argue with the value and performance of this setup.
Part# SC09MT2 (our 7.25" mini-twin rated to 800lb.-ft at the crank and which uses an Aluminum flywheel ) has a weight of 20-lbs. If you want to go even lighter you can opt for a Carbon-Carbon assembly which is 14-lbs. That being said...I don't see anything else listed that is even close on MOI.
I wasnt going for a twin based on the power level, more in hopes that it would last a bit longer and moi. I believe the monster twin is an 8.5", I could be wrong though, Steve? The 2 year warranty is an amazing deal, and its all USA made!!
A 20lb assembly would be great, 14lb=insane. Just when I was starting to lean toward a single disc ally setup...of course the ally flywheel did get me thinking that it may not be the greatest idea in a car with this much shock load and sustained high rev shock hits. Either way a SFI blanket is in order, I like my legs
I guess both the mini twin and the monster twin are to new for any real world results at this point. I already have a new set of arp flywheel bolts.
Jensen, sorry for the delayed reponse. Our flywheel does use a bolt on friction surface and this can be bought separately. Additionally, the Mini-Twin has been available for some time and is in use in cars both here and abroad including being used in Australian and European Touring Car series racers.
No problem Jeremy, I ended up pulling the trigger on a Quartermaster 7.25" button yesterday afternoon. I found out they are part of comp's vast empire and I get a 33% discount. Thanks for all the help fella's, I wish I could have purchased one from a LS1-tech sponsor.
