Any M6 guys remove your parking brake?
I was thinking about dropping more weight out of the car and was considering removing the entire parking brake assembly from the lever all the way back to the cables and shoes.
Any of you guys do this and just lock it in gear when parked? Anyone have any issues with this?
I bought my Camaro without the ebrake in it, and I just got all my parts to put the stock brakes back on. It hasnt been a problem driving it every day without the ebrake, but I just like the idea of having one. The Aerospace brakes that I have on the car do not have ABS capability either, and thats the main reason I'm swapping back to the stock setup.
Anyways, to answer your question...Yes you can drive around without your parking brake on a daily driver. As long as you park on pretty level surfaces it's not a problem. However, you will only drop about 10 lbs by losing your parking brake set-up, so unless this is a straight up race car I don't think it will be worth it. Hope this helps.
Bottom line is you can get away with it, but it's not worth the trouble unless it's a drag only car. Even then, I would find the weight savings somewhere else.
Save the manuals!
You gotta think that there's a reason why every car since 1905 has had a parking brake installed. I recall that putting a static load on the transmission (by not using the parking brake) is a bad thing. If I didn't have a parking brake, I'd make sure I at least had these in the car:
![](http://www.belson.com/images/7074-001-M.jpg)
... but that would negate any weight savings. ... and someone might steal them.
no parking brake hear just leave it in gear. running drag brakes.
I posted up the weights, the handle and lines I think were 7-8, and you can drill the spot welds and get the plate under the DS tunnel off, cut the handle moute off the concel metal. And get even more. The stuff on the rear end, the end brakets, the P loops that go on the cover, plus all the brake on the backing plates. makes the car alot easier to work on. I bet the whole stock system is 12-15pounds maybe more?
The trans/engine won't hold if you're on enough of an incline. It this isn't a concern of yours then hell, remove it! I've been in more than a few situations where mine wouldn't hold with it just in gear and I had to block a tire because the parking brake wasn't working.
I've thought about this for when I put drag brakes on the rear. One solution I came up with is plumbing in a hand brake like this, http://secure.chassisshop.com/partlist/6139/ , and making something to hook onto it to hold it tight when you pull it. Might be a pain in the *** but I think it could work.
Thanks for that info studderin. 12-15 is a good amount. Every little bit adds up.
No state inspection here to worry about. Plus I live in the Midwest where everything is straight and flat.
