T-56 Crossmember
Two questions....
Does anyone make a aftermarket crossmember for the stock trans? My Kooks TD's keeps hitting the edge on the drivers side back corner. I'm not sure if I want to just cut a small piece off or possibly replace it if I can get a little more clearance with an aftermarket one.
Also, do I need to support the transmission when removing the crossmember? This may be a dumb question but oh well.
Yeah, BMR, UMI just to name two.
http://www.umiperformance.com/catalo...ex&cPath=7_117
http://www.bmrsuspension.com/?page=p...d=55&catid=147
We do make the relocation kit for a T56, here is the link- www.umiperformance.com/2207
If you use the stock torque arm you will need #3004 bushing as well for the stock arm, see the bottom of the ad.
If I can help anymore please ask. Thanks!
Ryan
Ryan....I'm considering just getting a whole new torque arm with the bracket and doing it right. I'd probably prefer the long arm.
- Will that clear Kooks TD's?
- Do you recommend adjustable or fixed? I have most suspension upgrades and am lowered 1.25".
- May be getting a MWC 9" in a year or so, will your TA bolt up?
Thanks again!
Thanks again!
Thanks again!
Thanks again!
You should have no trouble with the Kook TD's... especially if it is clearing good with the stock torque arm. Our #2205 offers a little more room than the stock arm.
I don't know if our arm will bolt to a MWC. It will however bolt to all Stange and Moser rear ends, 12-bolt, 9" and S60.
Ryan
aftermarket, belair, crossmember, installation, instructions, ls1, m6, mod, number, part, removing, t56, trans, transmission, umi, ws6
