Trans. going in saturday!
Hey guys, i posted here about a week ago with my problem with my trans. The clutch isnt wanting to disengage after my engine build. i was told to check for a shim, check my PP torque and a few other things. i think i've come to the conclusion that the pp is too tight(about 60ft lbs) and my slave needs bled, the clutch was on the floor before i pulled it. looking at it logically, if it needed a shim wouldnt it had been acting like that before i pulled the trans? the only thing thats changed is the flywheel has been shaved which only would have caused it to disengage more right? idk any help appreciated. its goin in saturday!
