Please Help Me. Is This To Expensive
Old Dec 11, 2012 | 02:56 PM
Sinister_Z28's Avatar
Default Please Help Me. Is This To Expensive
Ok so my slave is leaking and it needs to be replaced. So i took it to a trusted shop. And they quoted me $1600 for a new oem hydrolics and clutch kit. The price includes labor. Does this seem high. And they dont want to install a stronger performance disk. I just need some advice and i need some soon. Thanks everyone.
Old Dec 11, 2012 | 06:30 PM
Caseythefalcon's Avatar
Clutch kit shouldnt be more then $5-600 and labor at maybe 4 hours. So I would say 1200 is the most I would pay for a clutch swap...that is of course if youre not trying to put a twin disc ram hd clutch in it lol
Old Dec 11, 2012 | 07:36 PM
Basically they are replacing the slave and clutch and fly wheel for that price. They want to put in a oem clutch kit and they are basically refusing to put in a after market clutch which is odd. So what is a good street strip clutch kit that will hold about 500 horse. I want to be making around 450hp with this car. What clutch kit would u recomend.
Old Dec 12, 2012 | 12:01 PM
WS600461's Avatar
Get a gm ls7 clutch holds 505 stock feel it will last awhile as long as ur not beating on it at the track with sticky tires. I have one but am in the process of upgrading to a monster stage 3 got my whole clutch kit minus slave and master for 600 bucks from co speed look at the monster stage 2 for a aftermarket clutch if u decide to go aftermarket holds 550 hp
Old Dec 12, 2012 | 01:51 PM
I actually have been looking at the Monster Stage 2 for quite some time now. Is it a direct replacement for the stock one. Also any down sides to the monster that i should now about it.
Old Dec 12, 2012 | 03:47 PM
WS600461's Avatar
My buddy has one in his ws6 and a tick master. clutch is I stiffer but feels so much better then stock. I would call and talk to them they make great products and will get u a great clutch. I'm waiting on my stage 3 to arrive my car has been down for a little over a month gettin the trans rebuilt can't wait to drive her again.
Old Dec 12, 2012 | 08:32 PM
I called monster today and they have great costomer service and i will definately be getting one. Now how hard is a clutch change as well as replacing the slave. Also this will be my first time doing a clutch swap any little details i need to be aware of.
Old Dec 12, 2012 | 08:53 PM
Exidous's Avatar
A clutch swap is easy technically but hard physically if you are solo and/or don't have a lift or trans jack. I did it solo with a reg jack for the trans with the car on stands and ramps.
There are tutorials on here about how to pull the trans and install the clutch.
$1600 is definitely steep for a clutch swap. I'd say $1200-1400 max.
Old Dec 12, 2012 | 09:17 PM
HCI2000SS's Avatar
I run a McLeod RST twin disk and love it. Feels totally like stock but grabs hard, and holds some pretty high power. Mine was $450 installed
Old Dec 13, 2012 | 03:40 AM
Any one know where i can find one of these tutorials that might have pictures. I plan on using a transmission jack. Also after i complete the clutch swap can i replace the trans fluid before i reinstall the transmission? Also how does the slave cylinder work as far as replacing it? Like is it bolt out bolt back in the new one?
