Hydraulic Clutch Line Problem
Ive got a 98 Camaro 3800 V6, Manual Trans. The Steel Braided Hydraulic Clutch Cable from the Master Cylinder to The Slave keeps blowing out with very little pressure behind it.
Ive replaced the Master Cylinder and the braided line with a used but in better shape line and now it comes off easier than before...
I've bled everything and it looks good, seals fine, then pop the hose comes back off....
Its got a updated slave cylinder on it with a metal clip insted of the plastic push clip. I need some help on this asap its a only means of transportation for me.
