LS7 clutch upgrade what slave cylinder is needed?
What slave cylinder needs to be used to do a LS7 clutch in 01 LS1/T-56 combo.
I have LS-7 clutch and pressure plate, flywheel and new LS7 crank bolts and keep finding contradictions the more I read on what is the correct slave cylinder to use with this setup.
