Dented crank during pilot bearing removal...
When trying to use an easy out to get the bearing out, I dented the back of the crank where the input shaft of the trans goes in at. It did not puncture a hole, but looks to be close. What is behind that wall, anything I need to worry about before installing my new clutch?
If it doesn't appear to be moved or cocked I would run the engine for a minute as the oil pressure would show a leak if it is punctured. You might sleep better knowing that you put a new one.
If it does decide to leak down the road it will ruin your new clutch.
