T56 cable drive speedometer modification
Old Jan 13, 2013 | 04:08 PM
alloy's Avatar
Default T56 cable drive speedometer modification
I do a cable drive mod to GM T56's that allows you to use both the VSS and a cable speedometer. I've been doing these for years now but haven't advertised much because the speedometer drive gear I use was discontinued, but just last week they became available again.
I modify your housing and include speedometer gears matched to your rear axle ratio and tire size. I've done a number of mods for people on here and over at thirdgen.org.
PM me for any questions you have.
Old Jan 19, 2013 | 12:38 PM
alloy's Avatar
I've just got my website up for my conversion. It's a work in progress
http://www.t56cablespeedometer.com/
Old Jan 19, 2013 | 06:30 PM
stevieturbo's Avatar
When the mods see this, you'll get a slap on the wrist for advertising. You'd maybe get more interest in the conversions section though
Old Jan 19, 2013 | 11:12 PM
alloy's Avatar
Didn't know where else to put it.
Old Jan 20, 2013 | 05:07 AM
The issue is more about non sponsor advertising. The conversion section is where guys are doing engine/trans swaps, and speedo operation is one big issue. Although guys there are working on a discreet electric motor drive to attach to their speedo units which doesnt involve a trans modification.
Either way, more options is always good.
Old Jan 20, 2013 | 11:37 AM
alloy's Avatar
I'm subscribed to the thread about the electric motor speedometer drive. Seems likes it's been a long time since any progress was made. It's a great idea if they can get it working.
Old Jan 21, 2013 | 05:12 PM
ls1_monte's Avatar
I had this mod done and it will work out very well in my monte carlo. I wanted to keep the stock interior and guages and this seemed to be the simplest way to hook up a cable driven speedo.
thanks again Alloy
Josh R.
Old Jan 27, 2013 | 11:34 PM
85GPLEf41's Avatar
Ls1monte did you use your factory speedo cable? I'm looking to get use Alloy's services My Grand Prix came with the th200c trans which i think it should be the same as the th2004r trans..
