A close look at the LG Motorsports/Emco sequential gear box
Hi guys,
I wanted to take some time for those looking at sequential transmissions and show you what goes inside of a purpose built unit, not just a conversion piece.
This is the same unit we have been running for seasons in GrandAm and very similar to the larger unit featured in our ALMS GT2 Corvette, and the very SAME unit you can buy for your own project.
With over 45 different gear ratios you can custom tailor this box to each track and your car for the ultimate in close ratio gear boxes
These are all built to order and come in almost 20 lbs lighter than the OEM gear box and feature pressurized, filtered oil to all bearings and gears. Straight cut gears with of course replaceable dog rings for engagement.
Assembled main case
![](http://i1144.photobucket.com/albums/o494/louisgigliotti/406BA082-2B06-4197-BEC8-1210AC5525D2-13718-00000C04D9EB9A40.jpg)
Tail shaft removed showing reverse gear
![](http://i1144.photobucket.com/albums/o494/louisgigliotti/91C12228-DD49-4D7A-8EA0-D72AC18DBB26-13718-00000C04DE94B74F.jpg)
Comparison of the reverse gear to the main gears
Notice how much wider the forward gears are
![](http://i1144.photobucket.com/albums/o494/louisgigliotti/E1AF539D-E6D2-42CF-9563-823ABEB1D904-13718-00000C04E43363EF.jpg)
Shift forks, notice they are gun drilled and feature pressurized oiling passages
![](http://i1144.photobucket.com/albums/o494/louisgigliotti/A67EF4CF-BD8E-4F95-B837-216B91721D9B-13718-00000C04EFF3A70A.jpg)
Look inside the main case. Notice the large roller bearings and also pressurized spray bar for oiling to the gears
![](http://i1144.photobucket.com/albums/o494/louisgigliotti/5A7F19FD-A4E5-4078-933A-9BA51A346C2D-13718-00000C04F4686569.jpg)
Main gear cluster
![](http://i1144.photobucket.com/albums/o494/louisgigliotti/828207AB-B1DB-43C5-8792-2E567C30D89B-13718-00000C04F7D335AB.jpg)
Huge main roller bearings for main shaft and counter shaft
![](http://i1144.photobucket.com/albums/o494/louisgigliotti/C1B5DCC6-C352-4F27-B0A4-87C24A24EB4A-13718-00000C05246C545F.jpg)
Main shafts and shift rail
![](http://i1144.photobucket.com/albums/o494/louisgigliotti/7FC7261C-21E9-427D-B6ED-3ACCFC7C0E8D-13718-00000C0528BE3F26.jpg)
Gun drilled main shafts, again with pressurized oiling passages
![](http://i1144.photobucket.com/albums/o494/louisgigliotti/CD5CFC11-01A8-4399-B5B5-1F772C6F7B25-13718-00000C052DAE57D5.jpg)
Main shaft support bearings in place
![](http://i1144.photobucket.com/albums/o494/louisgigliotti/3E52AD2D-92BD-4A5A-AC44-A0A9CFBC6791-13718-00000C053616BCBC.jpg)
Built in oil pump
![](http://i1144.photobucket.com/albums/o494/louisgigliotti/B9753D0C-DE2A-4044-9FF4-7EF97E2C751A-13718-00000C054CC4652B.jpg)
Fine micro filter assembly
![](http://i1144.photobucket.com/albums/o494/louisgigliotti/A9EC815C-8380-4D88-8CF5-F9F3C7DDAAC4-13718-00000C05594854C3.jpg)
Oil pick up tube
![](http://i1144.photobucket.com/albums/o494/louisgigliotti/4607E8B4-3782-439F-AE5F-1DB655A6D26F-13718-00000C05094E02C2.jpg)
[yt]OC4mtuu9YiU[/yt]
[yt]jUSPwmN9MWE[/yt]
As you can see it is more than just a face plated, or dog ring gear box T56 that goes into each one of these gear boxes.
While they may not be for everyone, I hope this shows you a bit more info on what goes inside of one of these awesome units! Feel free to hit me with any questions you have!
Assembled main case
Main gear cluster
Built in oil pump
Oil pick up tube
It's a little more than 10k take a look here http://www.lgmotorsports.com/product...oducts_id=2179
![Icon Lol](https://ls1tech.com/forums/images/smilies2/icon_lol.gif)
Yes, that is STILL a bargain compared to the; Quaife, X-Trac, FFD, and even some of the Hollinger units.
This is pretty much an unstreetable unit due to the straight cut gear scream, and how much you would kill said gears trying to drive it in stop and go traffic, correct??
![](https://ls1tech.com/forums/images/ranks/ls1tech20year.png)
Its not just the noise issue a straight or spur gear drive gears make with a box like this. The dog clutching teeth work great in a race situation but require finesse on the street. Also as a daily driver...these dog teeth will wear in relatively few miles...that is they will require "dressing" to keep / retain crisp shifts.
Stop and go your going to be on and off the clutch, most of the gear sets I have done have a 60-70 mph 1st gear in them.
The Corvette box is one of the more expensive units due to the front and rear adapters and goofy input/output shaft assembly on those. The standard fitment boxes with a traditional bellhousing and tail shaft are a bit cheaper but still running in the high teens to low 20's depending on application and other parts you might need.
