GM Parts Direct
I am ordering the LS7 clutch kit, looking on GM parts direct right now. Ive got the LS7 clutch kit, slave cylinder, and pilot bearing. Comes out to $606.xx after shipping.
Does the slave cylinder come with a t/o bearing?
Do I need different bolts for the flywheel or anything else?
From what Ive learned here on the forums, I really only need the different flywheel for the new clutch setup, which comes in the kit. Im changing the slave since itll be out, might as well. Just making sure I dont need anything else. If the master needs changed, ill do it down the road.
Awesome. Thank you! Im just wondering bc they offer the same kit as the monster website does, for 100 bucks less and then another 25 off with the discount coupon. And theyre slave cylinder is 70 bucks, as opposed to 150 or so for the OEM.
Will the LS1 flywheel and PP bolts work for the LS7 setup though? Or should I order those as well?
I really, really, really appreciate the help guys! I'd do the same in a heartbeat if I could and I always do when I can. If anyone ever has a question about music or guitar, Im here! LOL
![Cheers!!](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_cheers.gif)
