Clutch Recommendations?
Old Mar 3, 2013 | 06:36 PM
CaptObvious's Avatar
Default Clutch Recommendations?
So i am replacing my clutch in my 98 z28 ... alot of different makers out there, which have yall had the best luck with? any input would be great!
Also, since i am replacing the clutch, what else should i replace since the tranny will be dropped?
Old Mar 3, 2013 | 07:56 PM
Blackpanther99's Avatar
Monster is the way to go IMO or a LS7 clutch.
Old Mar 3, 2013 | 08:04 PM
If i go with a monster will i have to change out my flywheel? i know with the LS7 i do ... im by far no mechanic, which is why im here asking prior to ordering all the parts to drop off to the garage lol
Old Mar 3, 2013 | 08:13 PM
Rise of the Phoenix's Avatar
I'm going to follow this thread because I'm going to be upgrading my clutch soon too. I've read very good things about the Monster Stage 2 clutch, but it's a bit pricey. Are any of the Spec clutches any good?
Oh, and OP, how much is the clutch install going to cost you?
Old Mar 3, 2013 | 08:16 PM
i talked witha shop here, who told me they would charge 300 for the clutch install. so im figuring total cost around a grand.
Old Mar 3, 2013 | 08:24 PM
is the LS7 flywheel a direct fit into my transmission? i can get a ls7 clutch and flywheel for 400 ...?
Old Mar 3, 2013 | 08:33 PM
jc98ss's Avatar
clutch, slave cylinder, ARP flywheel bolts, ARP pressure plate bolts......flywheel is recommended but optional depending on what clutch kit you go with.....clutch master cylinder is optional too, you can do the "drill mod", buy a Tick MC adjustable or Mcleod.....Tick remote bleeder line makes bleeding super easy
which kit depends on what you plan to do with the car, how much you'll drive it, street or race.......you probably already know this, but if you're going to be mostly street, stay away from puck design discs.....Monster 2 or Spec 2+ are damn good street clutches that can hold decent power for a long time......Monster 3 and Textrailia Z are excellent street/strip clutches than shine on the track
Old Mar 3, 2013 | 08:40 PM
I like the price of the spec clutch...i have the option of a flywheel and pressure plate(standard or billet) from them... should i buy both? also, what exactly is the "Drill mod" and what is its purpose? ...
I only plan to see the track maybe 2 times a year, not on slicks...this is a daily driver, even when im done building it i dont expect to have much over 350-375RWHP
Old Mar 3, 2013 | 09:07 PM
LS1T56FTW's Avatar
Monster S.2 clutch with the lightweight flywheel. You can thank me later.
Old Mar 3, 2013 | 09:18 PM
jc98ss's Avatar
you can get the standard pressure plate which will be fine for a daily driver, but i went with the lightweight pressure plate option.....this makes it rebuild-able, i can have Spec rebuild it, then upgrade to a more aggressive clutch disc as my horsepower increases
drill mod is where you drill out the small passage from the clutch master cylinder into the line to allow for better high rpm shifting.....just do a search, there are several write ups.
Monster 2 with LW flywheel would be nice......for a street car at your power level that only sees the track a couple times a year and won't be on sticky tires, an LS7 clutch would also be fine.....upgrade to an LS2 flywheel, buy an LS7 clutch kit, drill mod, remote bleeder, new slave cyl, new bolts, and you'll be good to go.
Old Mar 4, 2013 | 11:03 AM
SNLPerformance's Avatar
All of our clutch kits come with flywheels.
Old Mar 4, 2013 | 11:11 AM
Rare96LT1Formula's Avatar
Just bite the bullet and grab a Monster Stage 2 with the standard 28lb billet flywheel, arp hardware, and a TICK MASTER!!
Money well spent.
Old Mar 4, 2013 | 11:13 AM
Guitar's Avatar
My Stage 3 feels great with the Tick Master. I love the pedal pressure and feel honestly. I'd get the Stage 2 depending on the power you're making and if you plan to stick there. I have no idea where I'm going with my car so I decided to go Stage 3 to make sure I had enough to cover it.
Old Mar 4, 2013 | 12:33 PM
On Tick's website, they have a "total package", which includes the Monster Stage 2 with the Tick Master Cylinder and all the bolts, etc. you need for $1,024.98. Would this be a good option on a heads/cam/150 shot car? Would a Spec Stage 2+ and a Tick Master Cylinder be ok too? It's about $350.00 cheaper.
Old Mar 4, 2013 | 01:25 PM
jc98ss's Avatar
I'd probably use a Monster 3 or a Spec 3+ for those mods, with the Tick MC also
Old Mar 4, 2013 | 03:37 PM
Guitar's Avatar
Stage 3 for sure with bottle.
Old Mar 4, 2013 | 03:41 PM
Thanks for the advice guys. Is one that much better than the other? I'm looking to do this the right way, but want to spend my money wisely.
Old Mar 4, 2013 | 03:50 PM
MertezWS6's Avatar
Iv'e had a hub break on my LS7 clutch going around a corner and hit a bump with 285/35/19 on the rear which I'm sure that was part of the cause, but after that experience I would never buy an LS7. Another bad experience of mine last fall driving hard and shifting fast I had my stock master cylinder go out and that is another bad experience when you have to drive it home with no clutch at all Riseofthephoenix that would be the best choice, maybe even a stage 3. you cant go wrong getting the stock master out of there
Old Mar 4, 2013 | 03:51 PM
Colorado Speed currently has the best price on the Monster Clutches, at least they did a week ago when I ordered mine. Paid $602.xx for the stage two clutch, standard flywheel, arp hardware. Ordered the Tick Master through the WS6store as I had a few other odds and ends to order there. Came out to less than $1000 for everything. Obviously, the stage 3 will run a little more, but Co Speed has a $110 off monster clutch code right now. I would suggest taking that route.
Old Mar 4, 2013 | 04:35 PM
Guitar's Avatar
I was going to order from Tick but they stopped their sales the same time I was going to order, so I ordered from Colorado Speed. Their website is HORRIBLE, but the prices were good.
