Shuddering problem... Help!
2. Improperly adjusted cover assembly
3. Bent or warped clutch cover
4. Worn pilot bearing or bushing
5. Dry or poorly lubricated pilot bearing
6. Dust, grease, oil or foreign matter in clutch
7. Gummy, glazed or worn clutch facings
8. Unequal spring pressure
9. Release levers binding
10. High spot on pressure plate
11. Flywheel not resurfaced at installation
12. Insufficient cushion in sprints or stamping of clutch plate
13. Broken, cracked, grooved or warped pressure plate
14. Heat flattened cushion springs
15. Flexible center or hub springs broken, weak or worn
16. Bent clutch plate due to installation error
17. Burrs on clutch plate splines
18. Bent main drive gear
19. Misalignment of clutch and transmission
20. Bell housing misalignment
21. Hill holder unit incorrectly adjusted
22. Loose or worn universal joints
23. Loose U-joint companion flange
24. Propeller shaft and U-joints misaligned
25. Excessive end play in rear spring shackles
26. Excessive backlash in U-joints or rear axle
27. Loose bell housing bolts
28. Loose or worn axle shaft splines
29. Loose flywheel to crankshaft bolts
30. Loose rear spring saddles
31. Loose rear spring U-bolts
32. Loose or worn engine and transmission mountings
33. Worn clutch fork
34. Worn throwout bearing
35. Throwout bearing carrier binding or cocked on sleeve
36. Heat-set diaphragm spring
37. Weak retractor springs used on diaphragm spring assemblies
38. Burrs on main drive gear splines
39. Dirt, burrs or nicks between flywheel and crankshaft flange
40. Worn torque shaft bushings
41. Loose motor support rods
42. Wrong type of facing used
Here's some info I gleaned off the web when I had chatter. Id look at the possibilities that have to do with heat.
-Junder
That's a lotta crap to check. It is the stock clutch, and I haven't messed with it at all. I guess it's time to see what Carmax's extended warrantee will do for me. I want to drop in a Stage II clutch, cam, and gears, but I was planning on doing that later, as most of my current $$ is tied up elsewhere. Well thanks! I have seen dampning springs go in the discs B-4, hard to say what it is without experencing it.
The only thing I might be concerned with is that it just started doing this?
How severe is the chatter/shudder?
If your problem just so happened to have started after an aggressive driving experience you might be able to gently wear the surfaces back in again. Do real low power/low RPM clutch engagements especially when the car is warm for the next 300 miles. If no improvement take it in.
Yeah, I did pretty much the same thing you did, and burned the clutch a bit. I'll try what u suggexted. -Thanks
