Adjustable Master.....
THANKS
You only need an adjustable master if there's upward pressure on the pedal when the pedal is released (if the pedal is pushing against the stop at the top). Ideally, you want the pedal *resting* against the stop, but not *pushing* against the stop.
If the master is pushing against the stop, you'll have the problem of the clutch not engaging all the way (it slips). Your problem sounds like the opposite - it's not releasing all the way.
With the shim in there, you've got a pre-load on the slave to pressure plate interface. So in theory, it should disengage the clutch earlier.
The only thing left (that I see) would be air in the hydraulics, not allowing the slave to fully travel to disengage the clutch.
THANKS
Just look for my post about a week or two ago ("A damn good question"). I'd give you the link but I'm at work and this computer's slow as hell. Anyways, I had the same problem and it's now fixed.
Troy
https://ls1tech.com/forums/manual-transmission/159885-damn-good-question.html
