Monster Level 2 & MGW Install Review
Let me start off by saying this is a positive review of both products and I couldn't be happier. The install was done at my buddy's shop and took us about 5 hours from start to finish. Everything in the Monster kit was top notch and the instructions were very useful.
The hardest part of the install was getting the OEM pilot bearing out and realigning the trans with the bell housing on re-installation. Both took some patience but can be done.
I also purchased a tick speed bleeder and let me tell you this thing is worth its weight in gold. It made bleeding the clutch literally a 5 minute job. My clutch fluid looked like black coffee before the bleed and the peace of mind knowing I can bleed the clutch at any time is awesome!
Per the pictures below I was shocked to see the hot spots on both the pressure plate and flywheel! The disk looked almost brand new but there was no way the pressure plate and flywheel would have lasted another 1k miles. I really cant believe the clutch didn't slip on acceleration. This is a good example for anyone considering a clutch swap from OEM.
Initial Drive:
The clutch pedal pressure has definitely increased over stock. It is not too bad where my leg gets tired, but it is very noticeable. The clutch grabs a lot lower than stock which I am getting used to but the engagement is like butter and it grabs hard.
The MGW shifter compliments the new clutch very well because of the rigidity. It would feel very awkward having a sloppy shifter and a stiff clutch. I honestly can't put into words how nice the MGW is but it makes a world of a difference in how the car drives. I read a lot of people had to get used to the location of the gears with the MGW, but that was not an issue for me what so ever. Every gear feels natural in where its located and makes for an awesome driving experience.
So in the end, I feel the cost for both kits is definitely justified and if anyone is debating on which clutch/shifter to go with I would highly recommend the Monster Level 2 and MGW.
Now, I just cant wait for the break-in to be over!!!![Cry](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_cry.gif)
Ugly LS6
![](http://i46.tinypic.com/2poqnt0.jpg)
Rear Engine Shot
![](http://i45.tinypic.com/j60vo5.jpg)
Look at all the hot spots/scouring
![](http://i45.tinypic.com/2ibjkll.jpg)
Same scouring on the flywheel
![](http://imageshack.us/a/img827/6632/oemflywheel.jpg)
Ls6 Disk- Looks great
![](http://i50.tinypic.com/15hiydh.jpg)
Beautiful Monster Segmented Kevlar Disk
![](http://i46.tinypic.com/2lvy5xv.jpg)
Monster Pressure Plate installed
![](http://i46.tinypic.com/15ysvph.jpg)
Comparison between factory Hurst and MGW
![](http://i50.tinypic.com/rvx91i.jpg)
MGW is about 3" shorter installed. Looks great with the Hurst ****
Initial Drive:
Ugly LS6
Rear Engine Shot
![](http://i45.tinypic.com/34qk5yp.jpg)
I hear yah, a clutch and install are pretty pricey but so worth it in the end... I feel/hear zero chatter when taking off. I can feel the clutch grab a lot more aggressively than before which is a nice feeling. The Ws6 store has an everyday price of $649 for the level 2 premium kit. I opted for the tick speed bleeder($50 bux) and with new bolts, the total was $720 to my door.
Ya when I did my m6 swap funds were running low so I just went with a stock clutch. I already have a tick and the slave has a lifetime warranty so ill probably just swap that for a new one when I do the clutch. I literally only need the kit, next time mister does a crazy special I may just go for it and opt for the lighter flywheel to reduce some rotating mass
Yes, I ordered directly from MGW. I did some searching and I dont think they have any vendors... IMHO the MGW will tie everything together perfectly... I did like my stock Hurst shifter for what is was worth. But with the new found firmness of the clutch, the MGW shifter is almost a must. The shifts just fall into gear with ZERO searching for gears... Its one of those things you just have to experience to really appreciate the feel.
Who doesnt have a bathroom scale? 455GTO that's who...![Bulls#!t](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_bs.gif)
On a side note. My now ex wife once wanted me to get her something that went from 0 to 200 in less 10 seconds for her birthday. So I bought her a bathroom scale
![The Jester](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_jest.gif)
iirc, 16mm threads is the stock setting. I also debated a corvette ****, but ended up going with a billet aluminum firebird engraved **** from WS6 store. Combo looks sick!
