Loose Hurst shift knob problem
Also, i've noticed there is a strange rattle coming from down there that i didn't notice before i installed the shifter. I found that if i apply force on the shifter in any direction, i can alter the sound or make it go away completely. Thoughts?
Hurst Shifter Shift **** Replacement Jam Lock Nut 16mm x 1.50 1983-2002 Camaro
Price: $4.39
This item is in stock
Sale Ends: 12/31/14
Brand new genuine Hurst jam nut in 16mm x 1.50 thread for Hurst classic ***** and T-handles with the stock OE **** threads found on 1983-2002 Chevy Camaro and Pontiac Firebird w/ 5 and 6 speed manual trans. If you have an aftermarket shifter or stick, be sure to know what threads you have. This does not fit Hurst chrome sticks- see my other listings. I also have Hurst **** jam nuts in many other thread sizes in SAE and Metric, as well as thread adapters if you are adapting a ****, email me to request.
http://www.core-shifters.com/servlet...ft-****/Detail
The trick is to get some Teflon tape from any home supply. ($0.99) Wrap it around the threads on the stick maybe 10-ish times and see how it does. If you add or take away wraps around the stick, you will dial in the orientation to be perfect and the tape will tighten everything so you can crank it down and it won't vibrate off.
